Show DHCP Relay Information
Perform this procedure to show relay information about DHCP routes and counters.
For scaling information on DHCP Relay forwarding (IPv4 or IPv6), see Fabric Engine Release Notes.
  1. Enter Privileged EXEC mode:
    enable
  2. Display information about DHCP relay forward paths:
    show ip dhcp-relay fwd-path [vrf WORD<1-16>] [vrfids WORD<0-512>]
  3. Display information about DHCP relay counters:
    show ip dhcp-relay counters [vrf WORD<1-16>] [vrfids WORD<0-512>]
  4. Display the options for each listed interface:
    show ip dhcp-relay interface [gigabitethernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}] [vlan <1-4059>] [vrf WORD <1–16>] [vrfids WORD <0–512>]
Display information for all DHCP relay interfaces:
Switch:1>show ip dhcp-relay interface
                                   Port Dhcp
PORT     VRF                     MAX MIN                ALWAYS CIRCUIT REMOTE TRUST
NUM      NAME             ENABLE HOP SEC   MODE         BCAST  ID      ID     CIRC
1/5      GlobalRouter     false  4   0     dhcp & bootp false  false  false  false
                                   Vlan Dhcp
VLAN VRF                     MAX MIN                ALWAYS CIRCUIT REMOTE TRUST  SMART
ID   NAME             ENABLE HOP SEC   MODE         BCAST  ID      ID     CIRC   RELAY
2    GlobalRouter     false  4   0     dhcp & bootp false  false   false  false  disabled
5    GlobalRouter     true   4   0     dhcp & bootp false  false   false  false  disabled
All 2 out of 2 of Vlan Dhcp Entries displayed
Variable definitions
Use the data in the following table to use the show ip dhcp-relay command.
Variable
Value
vrf WORD<1-16>
The name of the VRF.
vrfids WORD<0-512>
The ID of the VRF. The value is an integer in the range of 0–512.
Use the data in the following table to use the show ip dhcp-relay interface command.
Variable
Value
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
[vlan <1-4059>]
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
[vrf WORD<1-16>]
Specifies the name of the VRF.
Specifies the ID of the VRF. The value is an integer from 0– 512.
